42 Pages«<1516171819>»
Solid Modeling
New Posts Sizing an acis solid while maintaining aspect ratio
John Grub , 8/6/2015 7:15:21 PM(UTC)
1 5,256 murray Go to last post Go to first unread
8/6/2015 10:44:09 PM(UTC)
New Posts Model Layers Randomly Changing
On Reopening File, Random Layers' Colors Change
ZeroLengthCurve , 7/31/2015 2:19:17 PM(UTC)
0 4,190 ZeroLengthCurve Go to last post Go to first unread
New Posts Sweep to a helix spline
Any tips on how to make this work?
MaiFy , 7/17/2015 7:03:39 PM(UTC)
7 12,479 rokoko Go to last post Go to first unread
7/21/2015 8:15:52 AM(UTC)
New Posts Cutting out a circle/square from a solid
method72 , 7/14/2015 5:27:54 AM(UTC)
2 7,141 method72 Go to last post Go to first unread
7/14/2015 10:12:42 AM(UTC)
New Posts Cutting holes at right angles to the surface
How to emulate a router style cut in Sfx9
rolandw , 7/13/2015 12:49:51 AM(UTC)
3 7,313 Tim Olson Go to last post Go to first unread
7/13/2015 1:07:50 PM(UTC)
New Posts How do I fill holes in a solid or offset them?
mfontana , 6/24/2015 7:46:08 PM(UTC)
2 7,006 macnavi Go to last post Go to first unread
6/25/2015 5:08:01 PM(UTC)
New Posts Thicken Solid (from surface)
Method to create a constant thickness solid from a complex surface
PRP , 6/17/2015 6:23:46 PM(UTC)
9 14,922 PRP Go to last post Go to first unread
6/24/2015 1:46:09 PM(UTC)
New Posts can't subtract solid
want to achieve an imprinted symbol
rokoko , 6/21/2015 12:45:55 PM(UTC)
4 8,480 rokoko Go to last post Go to first unread
6/22/2015 11:03:06 AM(UTC)
New Posts How to smooth out transitions between solids?
Joints between swept and extruded and lathed solids too noticeable
G2Art , 6/15/2015 8:54:17 AM(UTC)
6 10,777 Tem Go to last post Go to first unread
6/17/2015 1:13:29 AM(UTC)
New Posts Can you not assemble parts in shark?
dhpt99 , 5/22/2015 1:52:56 PM(UTC)
4 8,535 masseng Go to last post Go to first unread
5/27/2015 5:39:36 AM(UTC)
New Posts Gear Model
Making Teeth
[+1]
BigBoy , 10/17/2014 3:15:57 PM(UTC)
13 22,307 BillB Go to last post Go to first unread
5/22/2015 2:08:17 AM(UTC)
New Posts Generating gcode from stp or step export
What are people using for gcode generation?
DanL , 3/21/2015 9:14:00 PM(UTC)
4 10,373 DanL Go to last post Go to first unread
5/17/2015 7:46:59 AM(UTC)
New Posts object info missing
part does not rotate with the rest
windward , 5/15/2015 1:19:42 PM(UTC)
1 4,809 Tim Olson Go to last post Go to first unread
5/15/2015 3:20:29 PM(UTC)
New Posts Viacad 9 pro - One rail sweep solid tool
Tool not working - One rail sweep solid tool
DavidTurpin , 5/14/2015 12:52:48 AM(UTC)
5 8,939 DavidTurpin Go to last post Go to first unread
5/14/2015 1:18:58 PM(UTC)
New Posts Creating enclosure with curved bottom. How to delete Circle? -viaCAD
What is the best way to create an encosure with a curved bottom.
Mark_S , 5/12/2015 4:55:31 PM(UTC)
2 6,248 Mark_S Go to last post Go to first unread
5/12/2015 5:46:03 PM(UTC)
Guest (165)
