42 Pages«<2122232425>»
Solid Modeling
New Posts Splitting a solid with a solid into two solids, then deleting one? (#4780)
MadOverlord , 7/26/2013 9:01:00 AM(UTC)
6 43,756 Tim Olson Go to last post Go to first unread
8/19/2013 12:14:42 AM(UTC)
New Posts The sketch to make an extrusion or revolve does not move with the part (#4788)
D3d , 8/2/2013 12:35:52 PM(UTC)
1 40,884 Tem Go to last post Go to first unread
8/5/2013 4:56:28 PM(UTC)
New Posts Redrilling a hole and adding countersink? (#4778)
MadOverlord , 7/24/2013 6:37:24 PM(UTC)
4 26,382 rockyroad_us Go to last post Go to first unread
7/27/2013 9:05:10 AM(UTC)
New Posts The Limit of 32 bit ... (#4755)
BPL-RFE , 6/26/2013 2:29:06 PM(UTC)
2 38,399 Tem Go to last post Go to first unread
7/11/2013 12:45:59 PM(UTC)
New Posts 3D fasteners (befuddled in CA) (#4761)
polygone , 7/9/2013 5:17:36 PM(UTC)
1 12,341 memphisjed Go to last post Go to first unread
7/10/2013 9:37:09 PM(UTC)
New Posts Remove hole from object (#4721)
workshopswarf , 5/6/2013 10:58:41 AM(UTC)
8 34,298 jb2953 Go to last post Go to first unread
7/2/2013 8:47:48 PM(UTC)
New Posts remove face from solid (#4724)
brianwhitecc , 5/8/2013 8:33:00 AM(UTC)
6 34,336 brianwhitecc Go to last post Go to first unread
6/10/2013 10:51:55 AM(UTC)
New Posts Unable to sweep surface to object... (#4725)
ZeroLengthCurve , 5/11/2013 1:35:50 PM(UTC)
2 24,185 zumer Go to last post Go to first unread
5/12/2013 5:08:00 AM(UTC)
New Posts Remove mesh when converted to solid (#4715)
macnavi , 4/11/2013 1:08:46 PM(UTC)
1 15,611 zumer Go to last post Go to first unread
4/13/2013 7:08:49 PM(UTC)
New Posts Annoying issue (#4695)
Trfsrfr , 3/11/2013 10:08:06 AM(UTC)
2 13,942 Trfsrfr Go to last post Go to first unread
3/31/2013 11:22:54 AM(UTC)
New Posts Editing Boolean Objects (#4699)
NWIR , 3/22/2013 3:02:38 PM(UTC)
3 10,686 NWIR Go to last post Go to first unread
3/23/2013 8:24:14 AM(UTC)
New Posts after using bend tool outline is left (#4688)
Darth , 2/22/2013 11:25:23 AM(UTC)
3 12,164 macnavi Go to last post Go to first unread
3/6/2013 4:40:33 PM(UTC)
New Posts Splitting a solid (#4683)
Sunstarer , 2/20/2013 1:16:49 PM(UTC)
5 10,645 rockyroad_us Go to last post Go to first unread
2/20/2013 8:25:21 PM(UTC)
New Posts Turners cube (#4656)
Dave , 1/24/2013 11:39:20 AM(UTC)
1 12,142 BPL-RFE Go to last post Go to first unread
1/27/2013 3:52:56 PM(UTC)
New Posts Thanks, Tim! (#4640)
ZeroLengthCurve , 1/5/2013 7:22:51 PM(UTC)
0 10,278 ZeroLengthCurve Go to last post Go to first unread
Guest (237)
