22 Pages«<89101112>»
Import/Export
New Posts how to change a still file into a solid ?
a.wieneke , 3/16/2015 2:53:36 PM(UTC)
10 20,130 Tim Olson Go to last post Go to first unread
4/3/2015 11:00:57 AM(UTC)
New Posts import .dat file
how can I import x y data
MacEdh , 3/21/2015 6:07:23 AM(UTC)
1 6,690 Tim Olson Go to last post Go to first unread
3/21/2015 1:19:33 PM(UTC)
New Posts Select Mask on imported IGES
Imported IGES select mask function issue
Tem , 3/13/2015 12:22:55 PM(UTC)
2 8,186 Tem Go to last post Go to first unread
3/13/2015 1:54:14 PM(UTC)
New Posts Stl export
No export
Jimbl , 2/27/2015 7:48:22 PM(UTC)
0 5,216 Jimbl Go to last post Go to first unread
New Posts How to troubleshoot IGES import
Iges file is not correctly imported
marton , 2/25/2015 12:51:39 AM(UTC)
4 10,412 marton Go to last post Go to first unread
2/25/2015 4:02:27 PM(UTC)
New Posts multiple lines each time we open
ukmacnut , 10/21/2014 9:32:18 AM(UTC)
3 10,577 memphisjed Go to last post Go to first unread
2/8/2015 2:36:31 PM(UTC)
New Posts Crash during export in DWG and DXF
I am not able to export a drawing in DWG or DXF
Nicolas , 1/19/2015 3:14:08 PM(UTC)
5 11,868 Nicolas Go to last post Go to first unread
1/20/2015 11:01:33 AM(UTC)
New Posts Basics? ViaCadPro 9
Need help with getting off the ground simple cad work?
Mastermarketeer , 1/11/2015 5:51:26 PM(UTC)
1 6,874 Tim Olson Go to last post Go to first unread
1/12/2015 12:08:21 PM(UTC)
New Posts TurboCad import ?
how to import Turbocad files in ViaCad pro9
Barro , 12/18/2014 8:23:28 AM(UTC)
1 6,241 Barro Go to last post Go to first unread
12/18/2014 9:43:46 AM(UTC)
New Posts Export crash on Mac
Export IGES or STE crashes every time
tmurphy , 12/9/2014 1:23:47 PM(UTC)
7 14,310 tmurphy Go to last post Go to first unread
12/12/2014 10:51:04 PM(UTC)
New Posts Importing AutoCad 2000 files
Some of these files will not open for me when I import them
Will , 12/12/2014 4:07:50 PM(UTC)
1 6,151 Tim Olson Go to last post Go to first unread
12/12/2014 4:39:46 PM(UTC)
New Posts Help: How to export to 2D so it shows a view other than" top view"
yuvalrakavy , 11/24/2014 3:24:39 PM(UTC)
3 9,591 Tim Olson Go to last post Go to first unread
11/25/2014 9:12:13 PM(UTC)
New Posts Punch 17.5 DXF exoprt
Scale error
aheytow , 11/21/2014 8:48:45 AM(UTC)
1 6,762 Tim Olson Go to last post Go to first unread
11/21/2014 4:02:10 PM(UTC)
New Posts can't export SLT ViaCAD2D/3D 9.0
the ok button is not active
Guest , 10/19/2014 8:15:43 AM(UTC)
13 24,713 Tim Olson Go to last post Go to first unread
11/21/2014 3:33:05 PM(UTC)
New Posts Import and Solidify STL
Cannot solidify STL with more then 2000 faces
Petre , 11/11/2014 1:13:09 PM(UTC)
3 10,021 Tim Olson Go to last post Go to first unread
11/14/2014 1:51:48 PM(UTC)
Guest (20)
