Surface Modeling
Cover Surface Problem - ViaCAD Pro V9 (#5147)
When I follow this exercise from the manual in ViaCAD 9
I get the error gaps detected in surface ? Fix Gap and try again.
kevjon attached the following image(s):
(26kb) downloaded 22 time(s). You cannot view/download attachments. Try to login or register.
Was thanked: 56 time(s) in 48 post(s)
Here you go.
Cover Surface with Guides.vcp
(10kb) downloaded 27 time(s). You cannot view/download attachments. Try to login or register.
I don't get the error. I think if you ellipse was made with curves and not closed, it will give an error. here's a video I made.
coversurface.mov
(729kb) downloaded 71 time(s). You cannot view/download attachments. Try to login or register.
I see what the problem is now. ViaCAD Pro 9 doesn't have the tool you show in your movie. It only has cover surface.
1 user thanked kevjon for this useful post.
Originally Posted by: kevjon I see what the problem is now. ViaCAD Pro 9 doesn't have the tool you show in your movie. It only has cover surface.
FYI: I have the same button missing (ViacdPro V9, Build 1109 on Mac)
Originally Posted by: ArtRedGreen Originally Posted by: kevjon I see what the problem is now. ViaCAD Pro 9 doesn't have the tool you show in your movie. It only has cover surface.
Found a Solution/WorkAround:
Pick from the Menu: Modify>> solid direct edit >> Deform Face other solutions are welcome...
Hi, I know this is no help but I have same problem too. There is no option for Cover Surface with Guide in ViaCAD V9 Pro but it is in the Manual and I have seen in Punch CAD Video on You Tube. When will this be corrected, Tim? Paul
Surface Modeling
