macnavi
#1 Posted : Wednesday, July 10, 2013 3:32:13 PM(UTC)
macnavi
Netherlands
The Escape key is a dangerous thing to use. When creating a bezier line and pressing the ESC key, the message appears if you want to cancel the action. Then it's too late, it already hangs and Viacad needs to be force quitted. The only way to cancel the action is right click to confirm the line and undo. The hanging not always happens, but it does happen so much that it is easily repeatable.
Is that only me or is it a bug and have other users the same experience?
Jean-Francois Jacques
#2 Posted : Thursday, July 11, 2013 10:34:15 AM(UTC)
Canada
I cannot repeat! Work fine here, I have no message for cancelling the operation.
METEORE DESIGN / KEKO Stand
SharkCad Pro V14 B1653
Platform macOS 14 Sonoma
#3 Posted : Thursday, July 11, 2013 1:41:25 PM(UTC)
With v9 (build 1075) I went to a more conservative approach with the ESC key.
macnavi
#4 Posted : Sunday, July 14, 2013 1:07:34 AM(UTC)
macnavi
Netherlands
Thanks for the replies. Here's a small video where you can see what happens. Try to replicate this!
http://youtu.be/0LDUqc7aezA
Tim, I've got build 1016, can I get the build you mentioned already?
