2D Drafting
3 Questions: Resizing (2d/3d), Placing/Alignment, Closed lines... (#497)
                Hi there,
                dge wrote: 1. ... What can be done?
the rectangle tool simply creates 4 line entities, if you want a 'real' rectangle entitiy use the polygon tool (with 4 sides and the polygon option) instead. For selecting the construction points of the lines connecting at the corner, use the deep select tool.
dge wrote: 2. ... I want to space the objects along the Y-Axis ... how is this done ?
have a look at the transformation tool bar (where you can find the rotate/move/mirror tools too) for the linear duplicate tool.
dge wrote: 3.  ... I would still love to have a single object (ashlar's  graphite does this easily ...  there must be a way to achieve this in viaCad??!)
there is no 'polyline' entity in the sense of one connected element available and I'm not aware of this type of object in graphite too (the connected line tool creates single lines/arcs only).
You might want to group the concerned elements instead or do a chain select (context menue > select chain) for selecting the whole 'multi element object' easily.
all of the above is derived from CU4 (Win) and therefore may look different in ViaCAD.
Norbert
                With regard to a single rectangular object as opposed to four independent lines forming a rectangle, if you will look at the box just above the data entry boxes, you are presented with a choice of "single line" (four independent lines), or "smart polygon (a single object).
                With regards to the seperate line segments in question #3, ViaCAD as well as CU has a Join Curve tool, which will take seperate lines/curves and attach them creating one long line segment.
    Todd Q
                Thanks!
                Todd Quinlan wrote: ... Join Curve tool, which will take seperate lines/curves and attach them creating one long line segment.
Be careful with the Join Curve tool if not only line segments are joined but e.g. an arc too. The resulting entity is resp. must be transformed to a spline which doesn't representate the original geometry any more and also needs more time for calculation (see control points).
Norbert
                posh.de wrote: Be careful with the Join Curve tool if not only line segments are joined but e.g. an arc too. The resulting entity is resp. must be transformed to a spline which doesn't representate the original geometry any more and also needs more time for calculation (see control points).
Danke norbert!
Thanks man, the info here helps...    for what I need it the join function just works fine...
daniel
2D Drafting
cannot  reply to topics in this forum.
cannot  delete your posts in this forum.
cannot  edit your posts in this forum.
cannot  create polls in this forum.
cannot  vote in polls in this forum.
