2 Pages<12
Mark
#21 Posted : Saturday, May 24, 2008 2:46:29 AM(UTC)
Mark
Tim,
1. Import IGES surface (or use any previously joined nurb surfaces) and split it with infinite plane using "Split Surface" tool.
It works, but:
- After splitting IGES, single Surface Face is taken apart into individual nurb surfaces, which have to be joined back along division line into sections to be usable.
(it is doable but also time consuming and difficult since some nurb surfaces are very small and easy to miss during manual selection).
Question: Can we have "Split Surface" tool option to split into 2 separate Surface Faces, instead of breaking it up into individual nurb surfaces?
2. Import IGES surface and split it with infinite plane using "Split Surface" tool. Select and delete nurb surfaces located on one side of division line. Select all, remove links and export to IGES. Import IGES back to Shark/ViaCad and see how it looks like (jpg 2 ).
Question: Is this the way it suppose to work?
3. Import IGES surface and stitch into solid using "Stitch Solid" tool (open volume option).
It works, but:
- Can't split resulting solid with infinite plane using "Split Solid" tool (removing links does not help).
(setup and file the same as in test no:1 with only difference that first I created solid from IGES and then tried to split it)
Question: What am I doing wrong?
It is possible to split IGES surface with infinite plane (test no:1 above) but solid created from the same IGES surface sliced with the same infinite plane and in the same location doesn't want to split.
Mark
Mac OSX10.5 Shark/ViaCad
Mark attached the following image(s):
1.IGES:Joined surface split.jpg (268kb) downloaded 0 time(s).
2.Splited IGES exp to IGES.jpg (211kb) downloaded 7 time(s).
3.Split solid error.jpg (270kb) downloaded 7 time(s).
Intel iMac-20,2 | macOS Ventura 13.3.1 | SharkCAD 14 |
#22 Posted : Thursday, June 5, 2008 4:10:24 PM(UTC)
ttrw wrote:
It should be worth mentioning Meshlab here too. Meshlab does pretty much the same thing as Polylab, but also works on Mac OS X (Intel), and is proper freeware ;)
What REALLY excites me is the possibility (I hope) to export from PolyCAD:
http://www.polycad.co.uk/exampl...ature_identification.htm
whatever drawings I make that I import to ViaCAD.
Guest (6)
2 Pages<12
