workshopswarf
#1 Posted : Tuesday, October 25, 2011 10:02:45 AM(UTC)
workshopswarf
Is there a way to type the diameter symbol into a text line?
phil
#2 Posted : Tuesday, October 25, 2011 10:22:18 AM(UTC)
phil
Looks like there's no easy autocad %%c way to do it :) The Alt-0216 method won't cooperate either.
Gotta do it the old fashion way... open the Accessories - System Tools - Character Map. Pick the matching font and select/copy this diameter symbol/character. Then go to Shark and paste it into the text line or editor box. :| bye
#3 Posted : Tuesday, October 25, 2011 10:48:30 AM(UTC)
Very easy on a Mac : Alt + Shift + 0 (zero) ...
workshopswarf
#4 Posted : Tuesday, October 25, 2011 2:23:01 PM(UTC)
workshopswarf
Thank phil, that worked fine.
#5 Posted : Tuesday, October 25, 2011 4:54:08 PM(UTC)
The Alt-0216 method dosent work with laptops unless it has seperate keypad for numbers or use the numbers above the "mkjo" keys and it works.
Should work with std keypads on keyboards as well?
#6 Posted : Tuesday, October 25, 2011 5:29:05 PM(UTC)
Mexico
alt+o
shift+alt+O on mac
Wit the "O" Letter, not with zero, (in my keyboard at least)
Luis G.
MacOSX Sequoia 15.7.7
phil
#7 Posted : Tuesday, October 25, 2011 9:08:57 PM(UTC)
phil
Jason you are correct! I forgot about the keypad use/requirement. After i hit the NumLk key, the Alt-mkjo works! Thanks
posh.de
#8 Posted : Wednesday, October 26, 2011 7:37:38 AM(UTC)
posh.de
Alt+0248 for the small one
for getting the character codes the free [URL="http://www.coolwintools.com/map_of_chars/mapofche.zip"]MapOfChars[/URL] (standalone, no install req.) is a neat alternative choice because the code of every char is listed.
Norbert
workshopswarf
#9 Posted : Wednesday, October 26, 2011 8:51:20 AM(UTC)
workshopswarf
I tried the alt 0216. Doesn't work with the numbers at the top of the keyboard but works fine using the number pad on the right of the keyboard. Good tip!
Guest (5)
