Custom template for model to sheet (#4905)
I have the same problem as misterrogers had in an older post. I have created a custom template and see it program files as C:\Program Files (x86)\Punch! Software\ViaCAD 3D v8 SP1\Templates\ModelToSheet When I use model to sheet my custom template appears in the drop down box, I can select my custom template , select the objects I want to include. The custom layout appears but there are no drawings, just the template. Function works fine using the other pre installed templates. I am using ViaCad 8 and windows 7 Can anyone advise please.
Thanks: 34 times Was thanked: 15 time(s) in 13 post(s)
going to guess you are missing viewports in your template. The easiest way I found to create template is open a mts template, edit your viewports and title block, then save as (name it different than original) back into the mts folder. keep in mind the template dimensions should be of paper size you intend to print to. could also be they are set to a custom zoom...
Great works fine now, thanks for your input.
