When I try and match a surface to a cylinder the object extends to the farthest point (on the "other" side). This happens even if I split the cylinder and get rid of the "other side" (which is pretty freaky). Is there a way to deal with this? There seems to be no way to match surfaces to the closest surface, is that right? Thanks in advance, Art MacIntell HEY, I'm a member! Woo Hoo!
Here is a movie of the problem in another form. The surface I am trying to match to is spherical.
What seems to be happening is that the surface is extending to some non-existent other side of the sphere.
Art
MacIntel
MatchFace.zip
(44kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Hello Art Just a thought but what happens if you rotate cylinder through 180? All the best Nick
Nick, That is a good thought, certainly as an experiment. But, on the cylinder, the extension goes to both sides (so rotating would look the same). On the sphere on the other hand, it just seems to go the wrong direction, so the rotation should give me something on the right surface. On the other hand, if you look at my movie, there is a revering or somthing that happens at the sphere origin...it is all very messy. Thanks for the response, Art
Can you post the actual file?
Here is one example. This happens to be extending a spherical shape but I have had this problems extending to and from spheres and cylinders. To me, a pretty serious problem. Try to extend the surface highlighted in blue to the surface highlighted in green. What I get is a big hoop. I have this problem on all sorts of files. This is actually a more complex example.
Art
MacIntel
matchface.cu
(40kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Yes .. these hoops are a huge pain - I think they may be an acis problem - but who knows I'm getting these hoops often when exporting to SolidWorks - presumably when a surface doesn't get trimmed back right Be great to collect some 'cases' of this - think I got one or two in my modestly proportioned :| folder entitled 'CUFUs'
Was this bug repaired in Shark? Here is my latest movie (and file).
Isn't this a simple problem?
Art
Mac 10.4 CU668
Bad extension.cu
(31kb) downloaded 5 time(s). ScreenSnapz.zip
(104kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
I can confirm that this happens quite frequently (though apparently in a random manner) and can be very annoying! Ciao, Norbert
Thanks, Do you mean it is still in Shark? Art
Sorry for the misunderstanding, I'm still using CU 4. Ciao, Norbert
No Misunderstanding, I am using CU4 as well. I just wanted to know if it had been addressed. I just bought Shark and I was hoping that this was one of the issues solved. Art
