misterrogers
#1 Posted : Tuesday, October 12, 2010 9:18:12 AM(UTC)
misterrogers
How can I render in the Sketch-style to a file?
I can see how to PREVIEW it on screen within my working drawing, but how can i render it as such to a high rez file as I would a regular rendering?
misterrogers
#2 Posted : Wednesday, October 20, 2010 5:52:10 PM(UTC)
misterrogers
Does anybody know how to do this?
Jean-Francois Jacques
#3 Posted : Thursday, October 21, 2010 9:08:09 AM(UTC)
Canada
Was thanked: 29 time(s) in 21 post(s)
Choose from the tools menu the Sketch Tool. Choose the type....Cartoon, Color Wash etc.
Then, make a preview if you want...and go to Render to File via the Tool. Apply the resolution and voil!
More....
http://screencast.com/t/oMYrmXFej
METEORE DESIGN / KEKO Stand
SharkCad Pro V14 B1653
Platform macOS 14 Sonoma
Maarten den Hartog
#4 Posted : Thursday, October 21, 2010 2:01:55 PM(UTC)
Maarten den Hartog
Was thanked: 4 time(s) in 2 post(s)
Jean-Francois Jacques, please check your saved result.
I followed your instruction but the saved file is not rendered as a sketch.
In your case it is rendered as Preview (with shadows).
Can anybody tell me how to render a sketch to file?
Maarten den Hartog
#5 Posted : Friday, October 22, 2010 12:02:08 PM(UTC)
Canada
I don't know what is happen??....I tried to do some tests for the Sketch Rendering....and it's impossible. Nothing after 1 hour. Also the standard render take an eternity!!
http://screencast.com/t/WTzpJw0Wk5Rv
#6 Posted : Friday, October 22, 2010 12:24:11 PM(UTC)
Canada
I tried again with a new file. Now I can do a Sketch Renders...but definitely not a render to file. I suppose its a bug!!
misterrogers
#7 Posted : Sunday, October 31, 2010 9:46:49 AM(UTC)
misterrogers
Yup still haven't been able to Render-to-File a Sketch style render. It gives a great preview (albeit an incredibly SLOOOOOOW one), but fails to allow me to render a nice high rez one to a usable file.
Someone please help fix this. It has great potential when showing concepts.
Thank you!!!
#8 Posted : Sunday, October 31, 2010 1:53:58 PM(UTC)
Yep - sketch renders are horribly slow - I don't think it's wired up right !?
#9 Posted : Tuesday, November 2, 2010 1:25:35 PM(UTC)
Canada
I confirm!
stefanmeir
#10 Posted : Tuesday, May 15, 2012 10:28:35 AM(UTC)
stefanmeir
Any news on this? I still can't render render to file in sketch mode in Shark FX v7 ... that's absurd!
#11 Posted : Tuesday, May 15, 2012 12:34:42 PM(UTC)
I must say that render module in shark an via cad is.... useless, to slow and buggy, for scotch render my recommendation is to use sketch up or (more expensive) cinema4d, that is what i do, export your model as .obj file will easy your life.
Luis G.
MacOSX 10.10, Yosemite
Shark FX V8, Beta testing Shark FX V9-1146
#12 Posted : Tuesday, May 15, 2012 3:56:42 PM(UTC)
Fixed in build 1010. You can also now Render to File the metal, glass, plastic & mirror presets.
I also made a change that opens and displays the file you just saved.
#13 Posted : Wednesday, May 16, 2012 2:16:51 AM(UTC)
- Why is sketch render so horribly slow ?
I simply can't use it
- Why can't I fence-select a specific area to render when in a rapidrender preset ?
