Viewing the plane?  How? (#3494)
                I know that repeatedly hitting "C" over an axis or point is for cycling-through/setting an arbitrary plane, but how do you VIEW from that arbitrary plane  ?
                Is Menu -> View -> View The Plane, what you need? Martin.
                If that is indeed the command you were looking for, I have another thought for you...
Assign it to a hot key, like z.
I did that and found myself using the z key more than you can imagine. So much so that I went to work and assigned the z key to view the plane on all the cad programs that I use!
I'm Z happy!
Mike...
(9kb) downloaded 5  time(s). You cannot  view/download attachments. Try to login or register.
                Or . . . press the A, S or D keys to view the default side, top and front views.
    Shark FX 9 build 1143
OS X 9.5
matter.cc
                Hahah Thanks guys!  the View > View the Plane was hidden from sight for me.  It magically disappeared from my absent-minded eyes.  And somehow it magically re-appeared.  I kept looking under the Work Plane menu. Speaking of shortcuts, I will say that I do use Z but it's currently assigned to Corner-to-Corner Square.   My Q is a straight line, and A is straight line from midpoint.  X is segment-at-location.  R is rotate, T is translate, O is convert object, E is explorer, I is eye-dropper, M is measure (maybe that was a default), P is point, S is select mask, W is mirror (since the letter looks like a mirrored object), and so on. Since i start all my modeling from 2d cad, I find that these few short cuts speed up my work flow tremendously.  Some of my peers still love autocad and mainly because of it's command line which I don't care for.
