How do you reset the axis after you rotate an object?
(please see pic)
Also, I have an STL that I'd like to change to a solid.
I get the error "Maximum number of facets is 2000"
Its in meshes right now.
Mogal attached the following image(s):
(24kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
The Reset Axis button in the Gripper Settings of Inspector.
(49kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
I was doodling with converting to solid from primitives in FX9 1109 and discovered that it returns that "less than 2000" faces error even when there are less than 2000 - for spheres. When I tried it with some other blocks, cones and cylinders, no notification appeared, though some had many more than 2000 faces.
Originally Posted by: Tim Olson >>How do you reset the axis after you rotate an object? The Reset Axis button in the Gripper Settings of Inspector. Tim
I don't have those options?!
(59kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
It is under the pull-down menu Attach. Select user-positioned you'll see more options.
