in ViaCAD, in drafting mode, when I zoom in and out, ALL the geometry in all the views flickers wildly. Is this the norm, or do I not have something set right? :confused: Mike...
Mike >>drafting mode You have created a model to sheet with draw views?
That is correct... Sometimes a picture is worth a thousand words... and a movie even more so. So I pulled up a sheet in ViaCAD, and took a movie of the screen while I'm zooming in and out. Although I did the movie in compact mode, you can display it double size, and see the flicker problem quite well.
BTW, I'm not using a wimpy PC. I have a Black Box Athlon 6400+ with a GeForce 8600 GTS with a Fill Rate of 10,800 MTexels/s, and a Spaceball! :eek:
Here's the movie...
http://www.mikenchell.com/images/flicker.avi Tim Olson wrote: Mike >>drafting mode You have created a model to sheet with draw views?
