List 1 bug you'd like to see fixed, but only 1... (#3511)
                I've been reading and seeing all your complaints about all the bugs that don't get fixed from version to version, or even from product to product.  So I had a thought.  What if we listed only the single most important bug we'd like to have fixed?  Would Tim focus on that single bug? Perhaps, because thinking about 1 bug is easier than thinking about 100 bugs.  So I suggest that everyone list only 1 bug that they'd really like to see fixed.  Then we can do an analysis of the replies and perhaps offer a suggestion to Tim.  Lets give it a try. List 1 bug you'd like to see fixed... but please, only 1.
Thanks: 3 times Was thanked: 2 time(s) in 2 post(s)
                My most unfavored bug is blends inverting inward (typically on multiple blend locations) wherein the display shows white areas as though the solid is a surface with unwanted openings. This results in invalid .stl files. Another interesting survey would be your most favored NEW feature, the analysis of which should give Punch! a nice, clear picture of priorities. MacPro quad, 6GB Ram, Wacom Cintiq 21
                There are just two bugs bugging me right now. The first and priority is the dysfunctional clipping plane. A neat tool but ever since the faces where added, all the lines show up in a clip plane when I show items. The other, is that when I start shark with another monitor attached the design explorer, snaps, and select mask windows disappear. I have to disconnect the monitor and restart shark. Mark
                draw an interpolate spline such that the end meets the start ... mMmm nice smooth curve results ! now .. undo last and then redo your nice smooth curve now has a kink - and if like mine it's a driving curve ... there's no obvious way to recover than starting again redo must always recover the pre-undo state ... otherwise it's not redo
