norbertsf
#1 Posted : Saturday, April 21, 2007 5:26:22 PM(UTC)
norbertsf
Great software!
The Purchase of ViaCAD has been great.
I have a question.
I have a plane with thickness that I have applied a "bend".
Is there a way to "slide/shift/translate" the bend along the plane without having to reapply the "bend" command?
My issue is that I cannot seem to place the bend in such a way that where the bend begins is in the correct location. I can place the center of the bend correctly, but if the starts and stops of the bends need adjustment, I cannot move the bend. It seems I have to "reapply" it. The stretch command is not working for me.
Norbert
NickB
#2 Posted : Saturday, April 21, 2007 7:57:21 PM(UTC)
NickB
With solids it is easy to change the location of a bend after you have bent your object.
The trick is to draw a line, where you want your bend to start, then use that line as the axis of your bend. If you then move the line, the bend will follow.
I always keep his type of geometry on a seperate layer and NEVER delete it unless I have deleted the part, want it to lose its history.
Shark FX 9 build 1143
OS X 9.5
matter.cc
norbertsf
#3 Posted : Saturday, April 21, 2007 10:18:36 PM(UTC)
norbertsf
SWEET!!!!!
Worked like a charm!
Thanks.
Norbert
