ALBANO
#1 Posted : Monday, February 26, 2007 7:27:50 AM(UTC)
ALBANO
A good feature would be to have the solid intersection tool with a modifier (alt-key) to retain one or both cut original solids!
This would make it really easy to develop inserts or covered cutouts or other parts that can be developed from a cut out region.
:) ALBANO
jabekci
#2 Posted : Friday, March 2, 2007 7:02:14 AM(UTC)
jabekci
I'll second that! I've often wished that the option key could be used with the intersect solid command to delete the intersection and keep the remaining portions.
Tem
#3 Posted : Thursday, March 15, 2007 1:00:10 PM(UTC)
Tem
That would be a time saver. shift select parts to merge, or press option to delete something out of the merge leaving a solid that you want instead of more parts to snip off next.
