FX support for 3Dconnexion SpaceNavigator? (#1629)
                Hello Forum,
                Originally Posted by: RAMA  Hello Forum,
Hi Rama,
You will need Shark FX 5.5. We went through certification with 3dconnexion on two devices for mac (Spacenavigator and Spaceexplorer).
                Oh, that's great news! I've downloaded 5.5 beta so will be up and running soon...
                Originally Posted by: RAMA  3Dconnexion SpaceNavigator.
Hallo,
does the 3Dconnexion SpaceNavigator works with ViaCad.
I would like to buy it also.
i could not find anything about viaCad support on the site of 3d connextion. But i think that i have read ( don't no where ) that it will work.
                Originally Posted by: awieneke  Hallo,
ViaCAD 2D/3D V6 supports SpaceNavigator.  V5 does not.
                Originally Posted by: Tim Olson  ViaCAD 2D/3D V6 supports SpaceNavigator.  V5 does not.
Great, i start to love ViaCad more and more,
particularly the bendigtool i used today very successfully:-)
                Originally Posted by: awieneke  Great, i start to love ViaCad more and more,
Thanks for the feedback.  Bending is fun to explore.  Bending along a curve also produces some very interesting shapes.
                Originally Posted by: Tim Olson  Bending is fun to explore.  Bending along a curve
Hallo Tim,
could you tell me moe ?
This sounds very interresting to me.
I used bending around axises and the 'middlebending'. wher can i found the function ' bendig along a curve' ?
hope my english is not to bad.
awieneke attached the following image(s):
(75kb) downloaded 4  time(s). You cannot  view/download attachments. Try to login or register.
                Originally Posted by: awieneke  Hallo Tim,
I made a quicktime movie in CU showing it applied to making a ring.
http://www.csi-concepts.com/Demo/RingBend.mov This feature is in Shark LT, Shark, Shark FX and ViaCAD Pro.
Your bend ring is very nice!  Feel free to post in the gallery, I'm sure others will find it interesting!
Thanks Tim, your film over bending is very good. It shows exactly, what up I looked in ViaCad
Can one select the bending path also inside?.  My idea is that the ring size does not change, if I change material thickness
Anyway, i should upgrade.
What would you suggest? ViaCad Pro (i can not find an upgrade version from ViaCad ) or one of the Sharks ( better later,  too expensively in the moment for me)
[SIZE="1"]'a result of my translation widget ' i hope one can read it[/SIZE]
                Thank you Tim,
thank you, this sounds great ! I will download a demoversion to try it.
MMMh,
where is the tool 'curve bend' in Shark LT ?
i placed  a question in the store. What they can offer to me.
back to the thread: I bought the 3dconnexion spacenavigator. It works fine.
But i could not find an easy way to navigate with the spacenavigator and select multible ( severel ) objects. as it is necessery to use the keyboard/an mouse, so i did before.
 Is it possible in ViaCad to make own keyboard shortcuts ? in the special one : Group/ungroup and show workplane/change workplanes.
maybe someone is interested in my bendingring see the file.
Another thing i discovered in this file: how easy it is to change the sequence in the features ( history ).
 bendring.vc3
(802kb) downloaded 4  time(s). awieneke attached the following image(s):
(14kb) downloaded 4  time(s). You cannot  view/download attachments. Try to login or register.
cannot  reply to topics in this forum.
cannot  delete your posts in this forum.
cannot  edit your posts in this forum.
cannot  create polls in this forum.
cannot  vote in polls in this forum.
