Roger Barrette
#1 Posted : Wednesday, July 4, 2012 1:25:26 PM(UTC)
Roger Barrette
Hi everybody,
I would like to start setting up a BOM for every part I design, but I have not a clue on how to start this off.
Also I would like to have some insight on how anybody would start showing a woodworking shop 's new employees on how to assemble the parts I am designing on paper.
Any thoughts or comments would be appreciated.
#2 Posted : Wednesday, July 4, 2012 7:36:15 PM(UTC)
Mexico
Was thanked: 29 time(s) in 22 post(s)
For BOM, this video might help:
http://www.csi-concepts.com/Demo/v4/SymbolsBOM.mov
Look also at the http://www.punchcadlabs.com/page3/page3.html
there are some good videos also on youtube, look for viacad or shark
BTW: where is the videos page that was on the old concepts webpage?
Luis G.
MacOSX Sequoia 15.7.7
Roger Barrette
#3 Posted : Thursday, July 5, 2012 8:57:47 AM(UTC)
Roger Barrette
When I open the Attributes & BOM window, a lot of of the lines are greyed out & I cannot fill them in.
I have the full blown version of Shark FX, so I don't understand why I cannot access these
misterrogers
#4 Posted : Thursday, July 5, 2012 12:43:14 PM(UTC)
misterrogers
Hi Roger,
Are you first selecting the item, and then clicking Apply to Selected or any of the other options?
#5 Posted : Thursday, July 5, 2012 2:30:44 PM(UTC)
Mexico
Many of the fields on BOM window are calculated values and can not be edited directly, I assume that that ones you are talking about are data input that are calculated from object properties, like material, volume, weight, name,... and so, and that values are taken from the objects itself once you assign them material and name. check the objects properties command on Verify main menu, select an object, assign some material, then open BOM window, select the object again and hit "Apply to selected" and see how those fields are self filled.
Luis G.
Roger Barrette
#6 Posted : Friday, July 6, 2012 7:07:32 AM(UTC)
Roger Barrette
Luis,
Thank you, that does solve a few issues. But its to bad that all that work is not automatically put into the Title Block.
That would be so much easier.
