Steve.M
#1 Posted : Monday, July 14, 2008 2:05:54 PM(UTC)
Steve.M
Hello,
I have just got around to installing the 2d/3d build 787 (win XP)
I find I cannot enable the "Show Curvature" for checking curves from the drop down menu. I set up a shortcut key but that only works if I have the mouse over the actual curve before I press the shortcut (even though the curve is already selected).
Regards,
- Steve
#2 Posted : Monday, July 14, 2008 3:43:52 PM(UTC)
Is it possible that you are not in the arrow tool?
Steve.M
#3 Posted : Monday, July 14, 2008 3:52:54 PM(UTC)
Steve.M
I was in the selection(arrow) tool to first select the curve for analysis.
The drop down menu(verify) "show curvature" is not working on this setup with this build,
#4 Posted : Monday, July 14, 2008 5:05:38 PM(UTC)
I cannot get show curvature to work unless I add a curvature circle and select both items. Then the curvature works.
Shortcut key works if the cursor is on top of the curve
Viacad v6 787
Vista
Steve.M
#5 Posted : Monday, July 14, 2008 5:12:17 PM(UTC)
Steve.M
Hi Jason,
Yes, that works on mine too lol
Have you tried a shortcut key as I mentioned in my first post?
#6 Posted : Monday, July 14, 2008 5:18:42 PM(UTC)
It seems to be ok on the Mac. Does Ryan need to get that ?
Steve.M
#7 Posted : Saturday, July 19, 2008 9:39:57 AM(UTC)
Steve.M
This is still not working in build 788.
#8 Posted : Saturday, July 19, 2008 12:16:55 PM(UTC)
Steve,
I believe I finally fixed it in 789. It was related to a variable not getting defined which is why it worked on some machines and not others.
Steve.M
#9 Posted : Saturday, July 19, 2008 12:46:41 PM(UTC)
Steve.M
Thanks Tim,
- Steve
Steve.M
#10 Posted : Tuesday, July 22, 2008 12:19:09 PM(UTC)
Steve.M
Hi Tim,
Confirmed as fixed in 790.
- Steve
Guest (11)
