Stefan
#1 Posted : Sunday, May 27, 2007 1:30:22 PM(UTC)
Stefan
Hi all!
This is actually my first "work" as hobbiest, in ViaCAD to get familiar with the toolset. Nothing fancy but it was fun to model. Brought into EIM for .obj export and rendered in Shade 8.5 Std.
Stefan
Stefan attached the following image(s):
joev
#2 Posted : Sunday, May 27, 2007 9:39:29 PM(UTC)
joev
Very nice! I'm not familar with Shade's rendering. Was it difficult to set up?
Stefan
#3 Posted : Monday, May 28, 2007 1:34:44 AM(UTC)
Stefan
Thanks, its actually quite simple. I used the Pathtracer option with 100 percent raytracing quality/noise reduction 1. Loaded a HDRI as lightprobe/spherical projection and adjusted the distant lights shadow settings to 50/50. The materials are standard materials except the metal colors, which i took 1 from a project included in the Shade 7 Designer LE Book.
Stefan
joev
#4 Posted : Monday, May 28, 2007 12:08:55 PM(UTC)
joev
I think I have Shade somewhere, I'll have to give it a try.
Thanks!
Redss
#5 Posted : Tuesday, May 29, 2007 10:32:31 AM(UTC)
Redss
Hi very nice Stofan
Stefan
#6 Posted : Tuesday, May 29, 2007 10:53:12 AM(UTC)
Stefan
Thanks Redss,
btw. if anyone is interested in Shade 8.5 Std., e-frontier is currently selling it for only 99 USD until Mai 31st...
Stefan
#7 Posted : Tuesday, May 29, 2007 9:40:41 PM(UTC)
Very nice!! Is that a face/face blend to get the legs?
Stefan
#8 Posted : Tuesday, May 29, 2007 11:18:51 PM(UTC)
Stefan
Thanks, yes i used the blend tool to create the legs.
Stefan
#9 Posted : Wednesday, May 30, 2007 7:00:50 AM(UTC)
Dear Stephan,
Nice picture!
You convinced me : I just bought Shade.
Thanks for the e-frontier special offer tip.
JL
Stefan
#10 Posted : Wednesday, May 30, 2007 12:02:20 PM(UTC)
Stefan
Thanks JL,
for me as hobbiest, im quite happy with the ViaCAD/Shade combination, the only think i hope that ViaCAD will get .obj export one day, so that i can omit the EIM translation route. I hope it will work for you aswell!
Stefan
#11 Posted : Wednesday, May 30, 2007 1:39:08 PM(UTC)
Stefan,
You're right, none of the direct export CU / import Shades are working.
In Shades the result is a partial and deformed object.
I tried DXF 12, DXF 2007, IGS no option, IGS full options...
It's very similar to what I get when I export CU to Artlantis 4.5 (except with VRML1 with this specific soft).
--> Tim, do you know why are these shader softs so bad in importing ?
It's a pity, because shades shading is really nice and easy with its example files.
JL
#12 Posted : Wednesday, May 30, 2007 2:17:09 PM(UTC)
Sorry, I've been too quick.
Importing in Shades is failing when the CU file is including solid elements.
Converting solids to mesh (or surfaces in some cases) in CU before exporting DXF 2007 seems to work fine.
(Don't try with IGS, it crashes Shades, even with a simple block).
JL
Stefan
#13 Posted : Wednesday, May 30, 2007 11:54:04 PM(UTC)
Stefan
Good that you found a solution for importing, i had not so much luck with DXF R12 (errors in the mesh), thats why i choose the .SAT-> EIM/.obj route. Will try again with DXF2000.
Just figured out that im a dummy, because i forgot to convert the solids into a mesh before exporting, thats why i had an error in the Shade mesh...
Stefan
Redss
#14 Posted : Friday, June 1, 2007 11:45:56 AM(UTC)
Redss
Hi is Shade 8.5 Std a add on for ViaCad
I just down loaded my ViaCad 5-31-07
Stefan
#15 Posted : Friday, June 1, 2007 1:48:01 PM(UTC)
Stefan
Shade is a modeling, animating and rendering program from e-frontier. I used it for rendering my ViaCAD model.
Redss
#16 Posted : Friday, June 1, 2007 6:43:55 PM(UTC)
Redss
Thank You Stefan
Guest (11)
