Import/Export
tessellation settings (#129)
Using EI Modeler you had an object export tessellation selection setting. Is there a setting like that in ViaCad to use before exporting as a fact file? Thanks
sah wrote: Using EI Modeler you had an object export tessellation selection setting. Is there a setting like that in ViaCad to use before exporting as a fact file? Thanks
You can convert the object to a mesh which provides a variety of tesselation settings. Use Edit:Change Object type to get access to normal & surface deviations, aspect ratio, and edge length parameters.
Tim Olson wrote: Use Edit:Change Object type ...
... or simply use the corresponding options within the export dialog?
Bernd
>> or simply use the corresponding options within the export dialog? Yes, the export to FACT command has the same mesh settings dialog box.
Import/Export
