Draw views question (#140)
                I recently purchased ViaCad and have been playing around trying to see what it can do.  So far, it seems it can do quite a bit for the money.  However, I have hit on a few snags, hopefully due to my ignorance and not limitations in the program.  The biggest of these is: How do you get a draw view to show an accurate (that is, containing curves & circles) 2D line drawing of an object?  The polyline approximation works as described, but can not be dimensioned.  The various rendered views can be dimensioned (although they don't work as well as the polyline views - for example, using the center option does not center the object like it does for a polyline view, and zooming changes the location and scale of the rendered object in the drawing view).  But how do you get to an accurate line drawing?  I've read the chapters in the manual a few times, but something is eluding me.  I would appreciate some help with this.
                I don't know if anyone is out there, but I worked on this some more, and this is what I found.   All of the rendered drawing views do not display properly; they do not appear centered when they should, and zooming in and out changes the location of the object in the drawing view window.  Actually, I should say the apparent, or displayed, location.  In some sense the object is centered correctly; I know this because I happened to move the cursor across an apparently empty draw view window and the snaps indicated that the object was there and centered, although I couldn't see it.   Finally, the object reverted to a line drawing in the correct (centered) location and scale when I flattened it (which answers my main question above). I should mention that in addition to the part being off center, there were other artifacts displayed, including large black areas, distortion of the part, etc.
                Joe, I'd like to see a review of model to sheet .. you can use it and most of the time you can get what you want, but it certainly has some weirdness as you say.
                First, thanks to all who have replied, I appreciate your input.
                Scott,
                Cant select a draw view - about half the time .. why ?
                further
                this function is totally munted
                when you fence select a "draw view" (that is incorrectly labeled a sheet view in the object edit box) .. you get an editable scale in the edit object box - which is really useful
                To clarify
                Hi JoeM,
                All of the above issues and requests submitted by Jol has been logged and brought to the attention of our development team
    Todd Q
                Todd, brilliant .. thank you !
                Tim,
                1) Is ViaCad only able to generate 2D drawings made up of polylines? That is, no arcs, ellipses or curves?
                A couple of issues with Draw Views that I have fixed this evening for ViaCAD and Concepts...
                A few more things I have noticed in ViaCad that I believe to be bugs:
                Joe .. be sure to drop it to
techsupport@punchcad.com
                Tim,
cannot  reply to topics in this forum.
cannot  delete your posts in this forum.
cannot  edit your posts in this forum.
cannot  create polls in this forum.
cannot  vote in polls in this forum.
