polygone
#1 Posted : Monday, April 21, 2014 1:14:49 AM(UTC)
polygone
Why don't these fillets appear in the concept explore?
missing fillets.sfx (148kb) downloaded 6 time(s).
polygone attached the following image(s):
missing fillets.jpg (50kb) downloaded 6 time(s).
L. Banasky
#2 Posted : Monday, April 21, 2014 5:05:01 AM(UTC)
L. Banasky
I removed the "Union" feature, and the fillets are displayed.
polygone
#3 Posted : Monday, April 21, 2014 6:42:06 PM(UTC)
polygone
The union is there because, dragging out a circle and extruding it is what I got use to. But, I think the software keeps better track of Protrusion Solid than my way.
It's interesting you got a different result then me. On my file, the union actually never was dissolved, and both the new part and the fillets are not removable. I'm using FX v8, did you get your result in the beta?
I missed your pic before responding, I think we got close to the same result. But, there actually should be four fillets not one. Did you remove union happen, it looks like it did.
polygone
#4 Posted : Monday, April 21, 2014 7:21:10 PM(UTC)
polygone
The file is junk... something happened to it. I tried to model to sheet it, but it had nothing but errors. I copied and pasted the object into a new file, and then, the model to sheet worked.
Something must have corrupted the file.
