Object rotate finer rotate resolution (#2153)
                The left, right, up, down keys will move an object, and pressing shift will cause them to rotate. But how do I get them to rotate/ move at a finer resolution? I can't find anything about this in the manual. :confused:
                Hi - at the bottom of the general section of the prefs you can change the nudge factor
(94kb) downloaded 0  time(s). You cannot  view/download attachments. Try to login or register.
                also .. pressing shift should I believe multiply your nudge factor by ten
                Sorry to nag Tim but that full explanation should really be documented in the U Manual
                LOL! Yes Tim, you put your foot in it a bit there!! ;)
                Do you know, I've just tried it, and there is no difference!!! :eek: A bug perhaps? I'll try again.
                It doesn't work!!!
                Hi Tom
                Originally Posted by: Tim Olson  Hi Tom
The nudge will only move geometry if the selection tool is selected. If any other tool is selected pressing the arrow keys moves the view.
                Originally Posted by: billbedford  The nudge will only move geometry if the selection tool is selected. If any other tool is selected pressing the arrow keys moves the view.
Yes but that now makes sense :) If selecting some dimensions to move, you wouldn't want to select them with the extrude tool? :)
- edit- although as said before, it would be nice if there was an ability to change tool using a right mouse button click/ contextual menu eh Tim? ;)
cannot  reply to topics in this forum.
cannot  delete your posts in this forum.
cannot  edit your posts in this forum.
cannot  create polls in this forum.
cannot  vote in polls in this forum.
