MarkS
#1 Posted : Saturday, September 8, 2012 11:28:47 AM(UTC)
MarkS
In Viacad 2D/3D, how do you turn off the 8-sided grid that goes around a point light source? It looked like Edit/Show points was supposed to turn it off, but that doesn't seem to make a difference.
Thanks!
Mark
MarkS
#2 Posted : Thursday, September 27, 2012 10:43:42 AM(UTC)
MarkS
There hasn't been any reply to this message, and I'm still wondering. It occurred to me that no one knows what I'm talking about. So I've attached a drawing showing the light. The light is surrounded by a grid showing the arrows. The help file says I should be able to toggle those arrows off by using "Show Points" (Control-D). But toggling this switch makes no difference.
Mark
MarkS attached the following image(s):
#3 Posted : Thursday, September 27, 2012 11:15:59 AM(UTC)
Not sure you can do that Mark
Why do you need to ?
.. To show a client ?
MarkS
#4 Posted : Thursday, September 27, 2012 12:55:42 PM(UTC)
MarkS
Hi jol,
Its supposed to be a point source of light, which I'm using to give the effect of an illuminated LED. The effect works -- except for the guide-line grid which I don't want at the moment.
Is there some other way to make light appear to be coming from an object?
Thanks!
Mark
#5 Posted : Thursday, September 27, 2012 1:10:06 PM(UTC)
Try to use area light instead
choose area light on the light palet, then select the object to be used as a light source
MacOSX Sonoma 14.7.1
#6 Posted : Thursday, September 27, 2012 2:25:41 PM(UTC)
I'm not sure that ViaCAD has 'area' lights Luis (!?)
Photoshop afterwards - would be the other answer
MarkS
#7 Posted : Thursday, September 27, 2012 3:05:43 PM(UTC)
MarkS
There are area lights. They aren't described in the user guide. You access them and 2 other non-described lights from a drop-down in the Inspector for the light.
Unfortunately, all of the lights have the associated light "guides", and no setting seems to be able to turn off that feature.
Mark
rockyroad_us
#8 Posted : Thursday, September 27, 2012 3:06:02 PM(UTC)
rockyroad_us
Did you go in the inspector?
MarkS
#9 Posted : Thursday, September 27, 2012 4:33:49 PM(UTC)
MarkS
As I mentioned, there are several lights available from the inspector, but as far as I could tell they all had the "guides" attached.
Mark
#10 Posted : Friday, September 28, 2012 2:32:03 AM(UTC)
Maybe that's a feature request then Mark
What do you think Tim - using CTRL D to toggle these scaffolds ?
