Option drag of a symbol and other Symbol Qs (#3669)
                When I drag a symbol into a drawing and then do an option drag of it to create a copy, the newly created item is now a group; it loses its name, BOM details and such.  Also happens with a EDIT>COPY>PASTE. If I need 100 nuts on an assembly drawing, its a LOT easier to drag the symbol over 10 times, then select all 10 on the drawing, then do a C-n-P of the 10, 10 times. Also when browsing symbols, there is no name/description show  Nuts all look alike and to drag one over to see which one it is is a drag.  Even a mouse fly over pop up of the file name would be big help. Is there a way to refresh the symbol bowser without restarting Shark?  I don't alway remember to save into the folder.
                Originally Posted by: Suds   If I need 100 nuts on an assembly drawing, its a LOT easier to drag the symbol over 10 times, then select all 10 on the drawing, then do a C-n-P of the 10, 10 times.
You could try the linear or polar duplicate tool to create multiples of objects, are you copying 3d or 2d objects?
Originally Posted by: Suds   Also when browsing symbols, there is no name/description show  Nuts all look alike and to drag one over to see which one it is is a drag.  Even a mouse fly over pop up of the file name would be big help.
The file name should pop up in box when hovering over symbol takes a second to show up
Originally Posted by: Suds   Is there a way to refresh the symbol bowser without restarting Shark?  I don't alway remember to save into the folder.
I don't think there is...
(32kb) downloaded 0  time(s). You cannot  view/download attachments. Try to login or register.
                Thanks Jason. I had Tool Tips turned off, so that fixed the symbol browser problem. The linear/polar duplicate also renames them with 'group_xxx'  They are 3D objects.
