2 Pages12>
#1 Posted : Friday, July 4, 2008 10:59:21 PM(UTC)
Hi All,
Here is an overview of the covering tools found in ViaCAD and Shark.
http://www.csi-concepts.com/Dem...ncedCoveringTutorial.pdf
I still need to go through the tutorial and mention which features are in Shark vs ViaCAD.
#2 Posted : Saturday, July 5, 2008 1:25:39 AM(UTC)
very good !
#3 Posted : Saturday, July 5, 2008 9:54:55 AM(UTC)
Yes very good work !
And I saw a nice Viacad logo on this pdf.
It's time to replace the viagra one on this forum header...;)
JL
#4 Posted : Saturday, July 5, 2008 10:15:00 AM(UTC)
.. I prepared a replacement for Tim a couple of months ago
How about it Tim .. it's old and it's shitty .. let's bin it !
unique
#5 Posted : Saturday, July 5, 2008 12:04:52 PM(UTC)
unique
Thanks for sharing Tim...I'll have a play ;)
--Paul--
unique
#6 Posted : Thursday, July 10, 2008 5:26:53 PM(UTC)
unique
Tim,
Working my way through it slooooowwwwwly....
Tangent cover surface - really nice indeed !!;)
unique attached the following image(s):
#7 Posted : Friday, July 11, 2008 8:47:38 AM(UTC)
Here are two SAT files that I use to test filling and capping with the G1 Cover tool.
It crunches for a bit, but produces some interesting covers.
CapFillExample.zip (25kb) downloaded 12 time(s).
unique
#8 Posted : Friday, July 11, 2008 8:58:49 AM(UTC)
unique
Tim:
Im having problems opening the file in any of my apps, I suspect its the latest ACIS, can you knock it back a couple for us pls ? ;)
#9 Posted : Friday, July 11, 2008 10:07:25 AM(UTC)
unique wrote:
Tim:
I rebuilt the SAT file, try download again from above post and see if that works.
unique
#10 Posted : Friday, July 11, 2008 1:36:00 PM(UTC)
unique
Yup, very good indeed...if only I didn't need to go back into Rhino for a good quick zebra analysis :rolleyes:
#11 Posted : Friday, July 11, 2008 2:24:30 PM(UTC)
Until zebras can run in opengl .. are we able to up the resolution and anti alias it ?
#12 Posted : Friday, July 11, 2008 2:37:48 PM(UTC)
jol wrote:
Current zebra is using pixel by pixel analysis which is why it's so slow, no AA. Increasing the resolution does help with current zebra plots which are based on facet vertices and normals.
I have implemented OpenGL environment maps as a surface verification option which you should be able to test in the not to distant future.
Steve.M
#13 Posted : Monday, July 14, 2008 7:40:10 AM(UTC)
Steve.M
Hi Tim,
As I mentioned in post http://forum.punchcad.com/showp....php?p=5316&postcount=29 there does appear to be a problem with the zebra with the actual output,.. well certainly I cannot understand what/why it is showing what it does.
As another example, I have a sphere with a flat, but looking at zebra both front and back veiws have the same result,... how could that be possibly correct?
unique
#14 Posted : Tuesday, July 15, 2008 1:31:36 AM(UTC)
unique
Tim: When you say this do you mean in the next month or three months or ??
#15 Posted : Tuesday, July 15, 2008 9:48:21 AM(UTC)
Not sure yet, we're still working on it. We're looking at moving away from pixel by pixel analysis to OpenGL environment mapping similiar to what some other packages are doing. So far it looks very promising.
http://www.csi-concepts.com/Dem...es/EnvironmentZebras.mov
ttrw
#16 Posted : Tuesday, July 15, 2008 2:53:58 PM(UTC)
ttrw
Tim Olson wrote:
csi-concepts.com/Demo/images/EnvironmentZebras.mov
Hey Tim that looks nice! Almost good enough to pop out and chew! :D
#17 Posted : Tuesday, July 15, 2008 8:13:56 PM(UTC)
:) It will be a good improvement. Being able to dynamically rotate the model and look for surfacing issues is very handy.
unique
#18 Posted : Wednesday, July 16, 2008 1:11:00 AM(UTC)
unique
Hats off Tim....nice job you dark horse!!
:D
#19 Posted : Wednesday, July 16, 2008 12:54:52 PM(UTC)
Having opengl reflected faces will be a HooJ improvement
The 'double horizon' envmaps in the library should hopefully give us an effect close to that of Alias StudioTools
I vote one of those as default !
Tim - I've very interested in seeing those particular backdrops in a dynamic envmap scenario for surface eval purposes !!
#20 Posted : Wednesday, July 16, 2008 12:55:31 PM(UTC)
oops .. here is a shot from ST
Guest (14)
2 Pages12>
