Arketype
#1 Posted : Monday, July 23, 2007 3:03:38 PM(UTC)
Arketype
Using verify properties in SP3 (660) crashes consistently.
Even if the selected object is just a simple cube.
Mac PPC G5 OS 10.4.10
#2 Posted : Tuesday, July 24, 2007 10:26:11 AM(UTC)
Was thanked: 173 time(s) in 105 post(s)
Arketype,
It doesn't crash with me, even with complex solids...
The guys will need more information :confused:
JL
Arketype
#3 Posted : Tuesday, July 24, 2007 11:46:12 AM(UTC)
Arketype
Attached is a simple 1" cube that crashed when choosing "properties", and the associated crash report.
verify: properties is crashing every time I try to use it.
Dave
CrashReport.txt (28kb) downloaded 4 time(s).
Cube.cu (7kb) downloaded 4 time(s).
#4 Posted : Tuesday, July 24, 2007 12:12:13 PM(UTC)
Your cube verifies perfectly on my MacPro (2 x quadcores).
On my old G4 it also works OK.
No doubt your crash is linked to your hard/soft configuration.
It needs to be punched!
JL
Stefan
#5 Posted : Tuesday, July 24, 2007 12:28:07 PM(UTC)
Stefan
Works here fine too (in ViaCAD), however i had the same probleme a while ago in ViaCAD and i fixed it by deleting a (preference or was it the override.ini, sorryi cant remember!) file.
Stefan
Arketype
#6 Posted : Wednesday, July 25, 2007 7:04:15 AM(UTC)
Arketype
I deleted all CSI preferences and now it's working.
Thanks for the help.
mugu
#7 Posted : Sunday, July 29, 2007 5:32:35 AM(UTC)
mugu
Arketype, I have the same problem with the verify properties tool. What exactly was your fix to the problem. Appreciate the help. thx.
Guest (5)
