Goolac
#1 Posted : Sunday, June 17, 2007 4:49:27 PM(UTC)
Goolac
I am trying to open a 34m STEP file and after around 5 minutes Viacad gets to 100 percent and then crashes with an error report. I am suspecting that 2gigs of ram may be the problem. I am running the latest of drivers for this system and it has opened several other STEP files just fine but after looking through my files I find that this one is the biggest one of them all and the next biggest one is 7m. Anything else I should check?
AMD X2 6000
2gigs ddr2 800
hd 2900xt 512m cat 7.5
#2 Posted : Sunday, June 17, 2007 9:31:50 PM(UTC)
Can you zip the step file (it should compress well as step is ascii) and send me the file to try?
Send to tolson@csi-concepts.com
