Tem
#1 Posted : Monday, July 15, 2013 10:04:03 AM(UTC)
Tem
Hi Everyone,
I have a project that could use a more "unit" relative plot curvature for an organic surface model.
It would be very helpful if I could enter a range of radii (i.e. from 10mm to 1.5mm) to find the curvature along surface regions.
Also, there would be an advantage to defining colors for critical curvature, for example I want to more easily see where the organic surface becomes equal to or less than 1.5mm so I could define any region of a surface (or group of selected surfaces) as red, and anything above that range as blue.
Thank you all.
