Suggestions
PowerPack question and Idea (#4952)
Hi Tim and Development team, What features are currently in the PowerPack for SharkFX? Can you list? Maybe with a description for each feature? I'm not clear on what you think we might need at this point. ALSO: Mesh shelling would be an excellent feature to have if you haven't already implemented. Internal support structure generation for mesh solids, to save material on a 3d print and retain strength & stability of 3d print. Thank you!
Hi Tim, Development team and Tem,
Originally Posted by: Tem Internal support structure generation for mesh solids, to save material on a 3d print and retain strength & stability of 3d print.
I definitely second this request.
Thanks and Regards,
Nicolas
I downloaded and tried out both the SFX and VCP betas 9. I noticed that while VCP has a shelling feature (NICE, by the way, and is a HUGE time saver), it is differrent from that in SLT and SFX. That's "interesting". Will SLT and SFX pick up natively or as add-ons an option that does the same thing VCP 9's shell tool does?
Suggestions
