Tem
#1 Posted : Thursday, September 2, 2010 11:45:11 AM(UTC)
Tem
Hi all,
I created an extrusion that was union-ed to the part it intersects.
Filleted the intersection created by the two parts.
From there, I added a counter sink hole feature, added a fillet to the inside diameter of the countersink hole (the top internal edge) and the sunk edge.
When I try to fillet the top outside edge of the extrusion an illusionary surface ( sorry I see it but it can't be selected) that seems to be a pretend cap on the lower edge of the fillet, so I can still see thew inside fillet just not the fillet on the sunk edge. Does this make any sense?
I will try to add two images to better explain.
Thanks!
Tem
Tem attached the following image(s):
Screen shot 2010-09-02 at 10.43.03 AM.jpg (40kb) downloaded 4 time(s).
Screen shot 2010-09-02 at 10.43.24 AM.jpg (62kb) downloaded 4 time(s).
rockyroad_us
#2 Posted : Thursday, September 2, 2010 4:56:13 PM(UTC)
rockyroad_us
Try the simplify object command. See if that helps.. I try to do that when things can't happen my way or expected.
Tem
#3 Posted : Friday, September 3, 2010 12:27:04 AM(UTC)
Tem
Thank you rockyroad_us.
In the end I created a solid to cut away material, creating the fillet. It was a lot of manual work. Next time I will try the simplify object command too.
#4 Posted : Friday, September 3, 2010 1:14:19 PM(UTC)
Hi Tem
Or if you can next time post the viacad or shark file.
