Text along a curve (#1528)
Does anyone else think that text applied along a curve looks wrong? It seems to me like the left side of each character is perpendicular to the curve rather than the centre line of the character. Things look odd when I engrave them. Anyone know of a work around please? Cheers, Martin.
Workaround : illustrator Yes .. it certainly looks wrong .. any chance you can take another look at attitude and spacing Tim ?
Will look into. You're right in that we are positioning wrt left corner when we should be positioning wrt center of char. Tim
Martin
Thanks for the heads up on this one. I made the fix in 802. As you noted,it makes a big difference where the alignment occurs. The top image is 802, the bottom image is 801.
Thanks again
(129kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
Great job done there, Tim. Thanks very much. It looks like you're working hard with improvements and bug fixes. Can't wait for the next release. Martin.
