Importing a reference image (#3446)
                Hello! I've got a problem with importing a reference image. Whatever type, jpeg or bmp, or image size I try - it gets blurry and unusable, no matter what resolution is set, medium or super fine. Looks like to scale 200x150 px image  up to 800x600 px. Maybe there is a trick to do it right? The only way I see - is to trace image in Illustrator and then import splines to viacad I'm using Viacad pro 6.
                Curiously, I tried to import a JPG image without success (no image just an out line), but with png my image is perfect.
    METEORE DESIGN / KEKO Stand  Jean-Francois Jacques, Industrial Designer  SharkCad Pro V14 B1653  Platform macOS 14 Sonoma
                Originally Posted by: Jean-Francois Jacques  Curiously, I tried to import a JPG image without success (no image just an out line), but with png my image is perfect.
have tried a png - and it works!
also I noticed that a resolution of original blueprint, from which I cut my bitmaps was 400 px/inch res, also changed it down to 72 dpi - maybe it was helpful too
Thanks, Jean-Francois!
                Xp ViaCad 7 Imports of JPG works OK.
