#1 Posted : Friday, February 6, 2015 5:35:31 AM(UTC)
Hello,
I would like to know whether Viacad Pro can do intersection curve as Solidworks ?
In viacad , Is Cut Section tool the same as intersection curve ?
If yes,please tell me where I can find any explain about cut section tool by movie or photo explain.
Please refer the following links of intersection curve .
http://www.pdweb.jp/oldpdweb/techniqe/sw0907_03.shtml
http://www.pdweb.jp/oldpdweb/techniqe/SW0904/hajimeSW_03_C09.JPG
#2 Posted : Friday, February 6, 2015 12:37:01 PM(UTC)
ViaCAD Pro can calculate:
--surface / surface intersection (Surface/Surface Intersection Tool)
--infinite plane/surface intersection (Cut Section Tool)
--curve/surface intersection (Curve/Surface IntersectTool)
It also supports projections, imprints, and trimming with intersection curves.
Edited by user Friday, February 6, 2015 12:39:20 PM(UTC)  | Reason: Not specified
#3 Posted : Friday, February 6, 2015 4:55:10 PM(UTC)
hello,
thank you ,this is what I wanted to know. !!
