#1 Posted : Saturday, May 11, 2013 1:35:50 PM(UTC)
I get this message:
"ACIS Error
! Sweep_to_body_limitation, sweep operation which result on sheet bodies cannot be swept to solid closed bodies.
In an earlier version of the file, there was no problem. Now there is, when I attempt to sweep to a solid made via a thickened surface. The sweep Rigid to Object works when the swept surface from curves terminates at a surface, however.
I simplified the surface, no joy.
I changed the lines to polylines, no joy.
I reversed the direction of the solid, no joy.
#2 Posted : Saturday, May 11, 2013 3:22:31 PM(UTC)
Interestingly, I CAN use the One Rail Seep Solid tool to create a surface out to the solid, and have it terminate.
zumer
#3 Posted : Sunday, May 12, 2013 5:08:00 AM(UTC)
zumer
The most likely reason is that the sweep body overlaps the boundary of the receiving face. Post the problem part of the file if you want a definite answer.
