#1 Posted : Tuesday, April 14, 2015 8:57:22 PM(UTC)
I've updated the ViaCAD Pro with PowerPack Beta to build 1155.
You can download a 30 day beta at:
http://www.punchcadlabs.com/page7/page7.php
Change Log 1155
• Windows 8 now supports correct display of multi viewports
• Mac now reverts to v8 Hidden Line libraries for "Internal Hidden Line" errors
• After writing a STL file, the object resolution is restored. Reduces size, improves response of app.
• Corrected crash printing draw views in pro, lt, fx on Windows
• Corrected extranious graphics when printing draw views in 2d3d on Windows
• Updated print name tweaks on Windows
• Preferences : FIle : Compact Files was switched
• Correction for improved planar covers with inner holes
• Correction for modifying arcs where start = end angle
• Correction preventing corrupt files when an object has more then 32000 associative links
• Mac now shows a dark circle inside the Close window when file is changed
• Correction for node locked builds expire (shark lt, fx), app now reverts to demo version (no file saves).
• Improved project curve procedures for very small curves projections
• Added support to zebra render without edges
• Added support for reading importing .sab files on Mac
• Option copy the previous line would not copy the line width correctly when in a draw view.
• PowerPack: Segment by planes was not getting all the planes
• PowerPack: More Updates for mesh to analytic tool
• PowerPack: Updates for revolve surface in mesh to analytic tool
• PowerPack: Updates all holes now checks normal
• PowerPack: Close all holes has edge option
• PowerPack: Updates to straight edge simplification
• PowerPack: Overhang now has option to specify hte overhang angle
• PowerPack: Improvements to how thickness is calcuated for min wall thick analysis
Change Log 1154
• Align Left/Right were flipped in the View Left Side orientation.
• Inspector Dimension : Font tab was not updating controls as they were modified
• Corrected a round off error with grid spacing when in metric units
• Updated Set Defaults command to copy all dimension attributes back to Inspector
• Updated the Spline File Format to read either xyz or xy data points
• PowerPack: Added option to detect revolved surfaces in Mesh to Analytic
• PowerPack: Close all holes now checks normal
• PowerPack: Thickness qbar stayed on menu after leaving tool
• PowerPack: Updates to straight edge simplication
• PowerPack: Improvements to mesh to analtic and simplify component option
Change Log 1153
• When a file fails to write due to permission, the full path is now displayed in the Alert dialog box.
• The Transform : Align tool now auto regens associative objects
• Join curve now highlights the resultant join as selected
• AI export now supports text outlines for 3D text (text not in top view)
• AI export updates when exporting while in hidden line display
• The Lathe Solid tool now correctly says "twist" instead of "draft angle" in prompt window
• The Mesh Bridge tool now supports bridging between triangles facets
• The Mesh Bridge tool now supports bridging between two edges
• Corrected issue with Mesh Booleans and normals
• Solid Extrude to Object now works with text
• Solid Lathe now works with text.
• Correction for mirrored meshes and bad normals
• The Work Plane now displays in the active draw view
• Selecting copied curves in draw views now highlight correctly
• Graceful exit from damaged files when reading in Layers
• Prevent crash with Add Solid and booleans with instanced self
• Corrections for text and dimensions placed in bottom draw views
• Correction selecting meshes located far from eye/reference point
• Join surfaces now allows joining two meshes.
• Gripper correction for leaving faces selected for next command
• Updates for push pull leaving construction faces around
• Updates for push pull and signed distances
• Deleting the facet of an associtive mesh now turns off associativity.
• Corrected issue of polygons printing
• Corrected issue of filled polygons displaying in opengl 3d views
• Added checks for possible parallel snap crash
• PowerPack: Corrected issue aligning all mesh normals
• PowerPack: Flip One Facet improvements
• PowerPack: Merge Vertices improvements
• PowerPack: Weld Vertices option to weld two selected vertices
• PowerPack: Added new circle normal to curve for tracing
• PowerPack: Corrected crash related to Surface from Grid.
• PowerPack: Correction to show just facet normal, not averaged normal for show facet directions
• PowerPack: Keep normal forward when doing vertex shading overrides. improves surface normal & overhang tool.
• PowerPack: Added support for chain selecting mesh edges
Change Log 1152
• Updates for Push/Pull of faces and changing distance via prompt window
• Added tool cursor to draw view offset sections
• Corrected two draw views highlight issue
• Updated the Solid Lathe tool to support group selections
• Corrected an issue where deleting a joined surface would incorrectly delete parents.
• Corrected issue with OBJ export and materials per body
• Corrected an issue sweeping polyines where an edge was not returned.
• Correction preventing Section Offset Views.
• Corrected a crash in dwg import where the font name was embeded in text string
• Corrected an issue preventing some keyboard commands from displaying in Short Cuts Dialog box.
• After reading a sat file, the progress dialog box was not reset, causing a read sat to display when exporting step
• Corrected issue where exporting step/iges would incorrectly display Model Size error.
• Corrected Mac End of Line feeds from classic to OSX (prevented obj files from reading into Rhino)
• PowerPack: Updated 3D Print Tool Icons
• PowerPack: Utilities are now in a tool palette with icons
Change Log 1151
• Correctly export non filled polygons to DXF/DWG
• Increased size of curves used in profile based solid commands
• Correction to the Edit Change Direction tool for meshes with subdivision
• Corrected crash joining two surfaces
• SketchUp now handles grouped objects better
• SketchUp now compacts shared vertices
• Updated SAT export popup to support R24
• PowerPack: Corrected issue with small support structures
• PowerPack: Added Show Non-Manifold Edges
• PowerPack: Flip one normal now displays normal status
• PowerPack: Coordinate Compare now shows max deviation even if all points are within specified deviation
• PowerPack: Added Undo for Change Name command
• PowerPack: Updates to dialog controls for Mesh to Analytic command
L. Banasky
#2 Posted : Wednesday, April 15, 2015 5:39:26 AM(UTC)
L. Banasky
Was thanked: 143 time(s) in 101 post(s)
Hi Tim,
Will there be Power Pack/Pro promotion for users like me, who purchased Shark FX9 upgrade before Combo promotion became available?
#3 Posted : Wednesday, April 15, 2015 9:26:44 AM(UTC)
Hi Larry
I'll send you a link via private email. I can't post the link public as Encore wants me to validate each customer.
Jean-Francois Jacques
#4 Posted : Wednesday, April 15, 2015 10:54:32 AM(UTC)
Canada
Was thanked: 29 time(s) in 21 post(s)
Big thanks Tim for this new option..... is very welcome for me!
"""Added support to zebra render without edges"""
..... But is not only for Zebra but Environment Map too!!
Now we can show a model like a polished and shinnied metal finish.
Edited by user Wednesday, April 15, 2015 11:06:02 AM(UTC)  | Reason: Not specified
METEORE DESIGN / KEKO Stand
SharkCad Pro V14 B1653
Platform macOS 14 Sonoma
#5 Posted : Wednesday, April 15, 2015 11:13:03 AM(UTC)
>>.....but Environment Map too!!
Yes, good idea, will add for next build.
#6 Posted : Wednesday, April 15, 2015 2:09:12 PM(UTC)
Canada
Tim, Environment Map without edges is already in your build (1155) !!!
Jean-Francois Jacques attached the following image(s):
Screen Shot 16.04.11.jpg (100kb) downloaded 11 time(s).
#7 Posted : Wednesday, April 15, 2015 3:06:04 PM(UTC)
Yup! Hooking it up for zebra also hooked it up for environment maps.
Mark
#8 Posted : Thursday, April 16, 2015 12:25:42 PM(UTC)
Mark
Hi Larry
Hi Tim,
I have also purchased Shark FX 9 upgrade before Power Pack/Pro Combo offer have been introduced. Can you private email me the link as well?
I sent you PM with my Serial number.
Mark
Edited by user Thursday, April 16, 2015 12:39:05 PM(UTC)  | Reason: Not specified
Intel iMac-20,2 | macOS Ventura 13.3.1 | SharkCAD 14 |
D.man
#9 Posted : Friday, April 17, 2015 8:37:08 PM(UTC)
I installed the 64bit beta, but i get nothing when trying to run the executable. I do have 32bit viacad pro installed in a different location, and it runs fine. My system is Windows 7, intel i5 quad core, 560ti video card.... nothing special..
#10 Posted : Saturday, April 18, 2015 1:55:48 PM(UTC)
What happens if you double click directly on the exe located at:
/Volumes/BOOTCAMP/Program Files/Punch! Software/ViaCAD Pro 9 64/exe/ViaCADPro.exe
#11 Posted : Saturday, April 18, 2015 11:00:15 PM(UTC)
Still the same issue. I had installed to a custom directory on a second drive. Also attempted re-install at the default directory on primary drive. If i double click the exe., i do see that ViaCADPro.exe runs as a process in the task manager, but nothing happens beyond that. Tried running as administrator, compatibility modes, etc.
Edited by user Sunday, April 19, 2015 3:20:38 AM(UTC)  | Reason: clarity
Guest (12)
