DavidTurpin
#1 Posted : Thursday, May 14, 2015 12:52:48 AM(UTC)
DavidTurpin
Hi All,
I just bought Viacad 9 pro for Windows 8.1 pro and I realized that the "One rail sweep solid tool" is not working,
am I the only one facing this problem or it is a bug?.
Thank you,
David Turpin
Mark_S
#2 Posted : Thursday, May 14, 2015 7:08:54 AM(UTC)
Mark_S
Hi David, Works for me. Try this. Draw a circle in isometric view and a line next to it. Make the line perpendicular to the plane of the circle. Then click one rail sweep solid, click on the circle, then click on the line.
I bought ViaCAD Pro about a week ago, so I'm just a little ahead of you, quite a learning curve.
Mark
WaveMechanic
#3 Posted : Thursday, May 14, 2015 8:17:47 AM(UTC)
WaveMechanic
Hi David,
It works for me too. WIN 7, 64-bit. VIACAD PRO V9 Build 1109.
Are you getting any error messages or is the icon just unresponsive?
Try it from the Menu instead of the icon (or vice-versa).
Did Mark's suggestion above work for you?
The Other Tim
Edited by user Thursday, May 14, 2015 8:20:17 AM(UTC)  | Reason: Not specified
WaveMechanic attached the following image(s):
Tim (NOT Tim Olson)
ViaCAD 2D/3D and PRO V9 1184, Blender 2.49-2.78.
Win 7 SP1, Core I5, 64-bit, NVIDIA G105M
DavidTurpin
#4 Posted : Thursday, May 14, 2015 10:24:15 AM(UTC)
DavidTurpin
Hi Tim and Mark,
Thanks a lot for your help, it was my mistake... :(
It is working fine now, I was not selecting the right option.
Best regards,
David
WaveMechanic
#5 Posted : Thursday, May 14, 2015 10:58:07 AM(UTC)
WaveMechanic
Excellent!
Tim (NOT Tim Olson)
DavidTurpin
#6 Posted : Thursday, May 14, 2015 1:18:58 PM(UTC)
DavidTurpin
Thanks again!
Guest (10)
