workshopswarf
#1 Posted : Thursday, July 16, 2015 12:25:09 PM(UTC)
workshopswarf
I have a solid drawn which is basically a rectangular block with several holes and cutouts in different faces.
I now want to reduce it's height so I have taken a slice from the centre by inserting a block and then removing it with the subtract tool.
How can I joint the 2 parts back together as they are still show as the same part, i.e when I click on one part both are selected?
rokoko
#2 Posted : Thursday, July 16, 2015 12:52:37 PM(UTC)
rokoko
hi,
have you tried the add solid tool? or try to group the 2 parts together. could you post a screenshot or file of your operation?
#3 Posted : Thursday, July 16, 2015 12:52:49 PM(UTC)
Try using Edit : Change Object Type Solid. This will make each solid region after the subtract a separate solid that can be moved.
workshopswarf
#4 Posted : Thursday, July 16, 2015 1:01:47 PM(UTC)
workshopswarf
Thank you Tim, that worked a treat!
horst.w
#5 Posted : Monday, September 21, 2015 4:28:17 PM(UTC)
horst.w
Fine tip !
I had the same problem. Now it is solved.
Horst
