3dup
#1 Posted : Tuesday, November 24, 2015 8:15:42 AM(UTC)
3dup
Was thanked: 5 time(s) in 3 post(s)
Hi
I try to make a "duster" for my milling machine...
This is only a test drawing to connect two pcs. I cant get it working?
Edited by user Tuesday, November 24, 2015 8:17:52 AM(UTC)  | Reason: Not specified
Untitled 1.vcp (86kb) downloaded 25 time(s).
#2 Posted : Tuesday, November 24, 2015 3:34:05 PM(UTC)
Originally Posted by: 3dup Go to Quoted Post
Hi
Hello
Try skin solid tool and see if that can get you what you want.
Untitledoption.vcp (172kb) downloaded 13 time(s).
#3 Posted : Tuesday, November 24, 2015 4:38:13 PM(UTC)
The loft tool only lofts between faces with no holes/cutouts.
You could do two lofts and subtract.
For Jason's skin solid method, you can also set the "perpendicular skin" option.
3dup
#4 Posted : Wednesday, November 25, 2015 1:22:02 AM(UTC)
3dup
This complex 3D is new to me, normally i only use 2D for milling.
Jason: I can see you made what i was looking for, but how you have done it I cant figure. Can you post some more hints or simple how-to?
The loft tool only lofts between faces with no holes/cutouts. -> Yes I found out, without the cutout it is working.
You could do two lofts and subtract. -> You will connect with "lofts" before making it hollow? If so how to make it hollow?
#5 Posted : Wednesday, November 25, 2015 10:14:35 AM(UTC)
You would loft the outside body and then loft the inside. Then subtract the inside loft from the outside.
mitchb
#6 Posted : Wednesday, November 25, 2015 7:21:43 PM(UTC)
mitchb
Was thanked: 76 time(s) in 38 post(s)
I did this by making a cylinder and a block. Used the Solid Loft tool to loft between the parts, I then shelled the part selecting both ends as open.
Mitch
mitchb attached the following image(s):
Screen Shot 2.png (273kb) downloaded 10 time(s).
horst.w
#7 Posted : Thursday, November 26, 2015 2:02:07 AM(UTC)
horst.w
Yes, that's right. But because often you can't see both ends, the tric is to change the view to wire-grid. Then you can click with the mouse also on the backside of the surfaces you want to let open. (multi-choice).
H.
mitchb
#8 Posted : Thursday, November 26, 2015 2:25:21 AM(UTC)
mitchb
Generally speaking you're right that an unseen face can't be selected but in this case, wire frame was not used because the ambiguity popup offered the back face as a choice. I clicked on the top surface close to the back edge to get that popup.
Mitch
3dup
#9 Posted : Thursday, November 26, 2015 11:25:40 AM(UTC)
3dup
Thanks for the help, it's real nice. I have it running now:-)
horst.w
#10 Posted : Thursday, November 26, 2015 12:11:06 PM(UTC)
horst.w
Mitch
Thats clear! It's only a more than simple example that doesn't need a wire frame because the requested part in the list of only two is recognizable red highlighted.
Horst
Claus
#11 Posted : Friday, November 27, 2015 7:47:11 AM(UTC)
Claus
Denmark
select one open end while holding down the shift key, continue holding shift while you middle-mouse-click to rotate the view to make the second end visible. Hold additional keys to pan (forgot which). It's a bit like playing the piano but changing view during operations is essential.
horst.w
#12 Posted : Friday, November 27, 2015 12:10:42 PM(UTC)
horst.w
You mean perhaps <Press down Mouse-Wheel an move mouse> to turn around the whole object ? Great! That helps (in most cases).
H.
Edited by user Friday, November 27, 2015 12:12:31 PM(UTC)  | Reason: Not specified
