horst.w
#1 Posted : Wednesday, December 2, 2015 5:37:29 AM(UTC)
horst.w
Hi
is there a way to subtract an imported STL from a volumebody? I need the negativ form.
I tried to convert the STL to a volumebody but earned a error message > please have a look to the pictures
Horst
Edited by user Wednesday, December 2, 2015 5:41:07 AM(UTC)  | Reason: Not specified
#2 Posted : Wednesday, December 2, 2015 10:48:44 AM(UTC)
If you post the STL file, I'll see if PowerPack Pro can convert it and post the model.
horst.w
#3 Posted : Wednesday, December 2, 2015 11:52:26 AM(UTC)
horst.w
Thanks, it is attached ...
Horst
Scheibenritzel_st1300_v2.zip (237kb) downloaded 21 time(s).
24c
#4 Posted : Thursday, December 3, 2015 2:03:10 AM(UTC)
24c
Was thanked: 63 time(s) in 45 post(s)
Interesting part Horst,
I quickly put it through PowerPack Pro, and I used a reduce triangle, convert to quads & Mesh to Analytic conversion.
I reduced the triangle count a bit too much, and it became faceted, but it definitely was a solid, and I know Tim will do it better. :)
Mike
Edited by user Thursday, December 3, 2015 2:05:10 AM(UTC)  | Reason: Not specified
pcf-horst.sfx.zip (1,008kb) downloaded 10 time(s).
horst.w
#5 Posted : Thursday, December 3, 2015 10:39:40 AM(UTC)
horst.w
Many thanks, but Iam using ViaCAD Pro 9 and can't open sfx-fils from Shark. (Punch-file does'nt work? the computer is hanging)
The wheel is part of Hondas motocycle ST 1300 windshield- elevator gear.
@ Tim Olson
The PowerPack for ViaCad Pro 9 is also able to convert this?
Horst
#6 Posted : Thursday, December 3, 2015 2:05:10 PM(UTC)
You can rename the extension to .vcp.
PowerPack Pro is the same add-on for ViaCAD/Shark.
horst.w
#7 Posted : Thursday, December 3, 2015 4:34:53 PM(UTC)
horst.w
Many thanks for the informations!
Sincerly
Horst
