#1 Posted : Tuesday, June 30, 2009 3:49:11 PM(UTC)
This is an early stages 3D model of a ship i designed on paper. That one was my second ship. I have others following it on paper. It takes a loonnng time to do this, but i'm having fun.
I model the hull in Delftship, then adjust to suit the hydrostatics i think are reasonable based on overlaying the model on an existing hull model. On paper, years ago, i had to do this by hand, using photos and extrapolating information, as i am not a naval engineer. I then export the curves as .dxf and import into ViaCAD.
ZeroLengthCurve attached the following image(s):
2009-06-27-2000-e bow.jpg (38kb) downloaded 6 time(s).
2009-06-27-2000-e elev port side.jpg (51kb) downloaded 7 time(s).
2009-06-27-2000-e inboard elev with stns and stns feet turned on.jpg (70kb) downloaded 5 time(s).
2009-06-27-2000-e stbd quarter-beneath with more tvbhds visible.jpg (88kb) downloaded 6 time(s).
2009-06-27-2000-e keel view.jpg (80kb) downloaded 5 time(s).
2009-06-27-2000-e bow view with hull mesh transparent.jpg (47kb) downloaded 5 time(s).
2009-06-27-2000-e plan view.jpg (77kb) downloaded 6 time(s).
2009-06-27-2000-e port elev of bow area.jpg (102kb) downloaded 6 time(s).
