solidtooldesigns
#1 Posted : Thursday, February 18, 2016 10:19:52 AM(UTC)
solidtooldesigns
I'm trying to stitch a group of surfaces into a solid. There are about 1450 surfaces though. How can I tell where the problem is ?
solidtooldesigns
#2 Posted : Thursday, February 18, 2016 10:50:34 AM(UTC)
solidtooldesigns
I tried uploading but am getting an error uploading the file...
solidtooldesigns attached the following image(s):
#3 Posted : Thursday, February 18, 2016 11:23:30 AM(UTC)
There is a detailed log file that is created in your preferences folder called healing.log. It can tell you if the geometry was good going in.
If you have PowerPack, something I find helpful is to stitch the surfaces together with Closed Volume Required turned off. Then use the PowerPack: Show Free Edges to isolate the edges that were not shared.
Sounds like you hit the maximum size for attachments.
solidtooldesigns
#4 Posted : Thursday, February 18, 2016 12:54:03 PM(UTC)
solidtooldesigns
Ahh okay. I had a feeling the Powerpack would have what I'm looking for.
The file I tried to upload was less than 7mb. Weird.
