Thanks: 2 times Was thanked: 32 time(s) in 26 post(s)
Hello Tim,
How can I weld that blue surface on the green volume please?
Thank you.
Antoine
velo.sfx
(146kb) downloaded 12 time(s). Antoine attached the following image(s):
(236kb) downloaded 10 time(s). You cannot view/download attachments. Try to login or register.
There is the solution to convert all surfaces, then weld it all with the tool: Stitch.
But I would like a simple solution, if it exists.
(187kb) downloaded 12 time(s). You cannot view/download attachments. Try to login or register.
Hi Antoine
Do you need the previous underlying blend? It looks like they share the same space. If not, remove the blend with deep select and then do a Solid Boolean Add with the surface.
Edited by user Wednesday, February 24, 2016 12:04:35 PM(UTC)
