luk72
#1 Posted : Tuesday, March 8, 2016 1:01:35 PM(UTC)
luk72
Hi, see the attachment. tested on ViaCAD 2d3d v8.0.3 (b1016), ViaCAD Pro v9.0.4 (b1166); AMD FX-6300, nVidia GeForce GTX 750, 8 GB RAM
Edited by user Tuesday, March 8, 2016 1:12:41 PM(UTC)  | Reason: Not specified
luk72 attached the following image(s):
#2 Posted : Tuesday, March 8, 2016 1:04:42 PM(UTC)
Hello
Can you add the attachment
#3 Posted : Tuesday, March 8, 2016 2:17:02 PM(UTC)
Regarding the 2nd issue. This is a bug, as its not sweeping between the 2 points the use picks. Its using other points on the curve or control points instead of user selected points.
luk72
#4 Posted : Tuesday, March 8, 2016 2:48:53 PM(UTC)
luk72
Thanks for reply Jason.
Lukasz
Edited by user Tuesday, March 8, 2016 2:50:02 PM(UTC)  | Reason: Not specified
#5 Posted : Wednesday, March 9, 2016 2:59:48 PM(UTC)
Thanks for the heads up. The Sweep Between Two Points issue is now corrected in builds 1192 and above.
