Solid Modeling
Windows sizes-shapes and sweep between points problems
Hi, see the attachment. tested on ViaCAD 2d3d v8.0.3 (b1016), ViaCAD Pro v9.0.4 (b1166); AMD FX-6300, nVidia GeForce GTX 750, 8 GB RAM
Edited by user Tuesday, March 8, 2016 1:12:41 PM(UTC)
luk72 attached the following image(s):
(472kb) downloaded 12 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: luk72 Hi, see the attachment.
Hello
Can you add the attachment
Regarding the 2nd issue. This is a bug, as its not sweeping between the 2 points the use picks. Its using other points on the curve or control points instead of user selected points. Regards Jason
Thanks for reply Jason.
Lukasz
Edited by user Tuesday, March 8, 2016 2:50:02 PM(UTC)
Thanks for the heads up. The Sweep Between Two Points issue is now corrected in builds 1192 and above.
(95kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Solid Modeling
