I'm brand new to this program and so far I'm liking it. I've gone thru the menus and here in the forum and I can't seem to find a feature that I use a lot in my work. I manufacture investment molds. So I get a drawing and have to add a shrink factor to it. I import customer supplied prints, then usually just "resize" them to make a mold print. For example a print dimension is 1.000" to which I add say 25% for a total of 1.25" on the mold I make. Is this feature available? If I missed it somewhere I apologize and appreciate a direction to head in. Thanks in advance! Richard
Hi Richard
If you need to modify the actual 3D part there are a collection of tools in the Local Face Modeling palette that might help. (Chapter 38 of user guide). You can draft, offset, and move faces of a part.
You can use negative values in the thicken and offset tools which will shrink a part.
To use a draw view scale, check out the video Creating 2D drawings from 3D at the 2:20 minute mark.
http://masterviacad.com/videos/page7.html Tim
Edited by user Wednesday, March 9, 2016 11:12:09 PM(UTC)
(25kb) downloaded 13 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: rlmora I'm brand new to this program and so far I'm liking it. I've gone thru the menus and here in the forum and I can't seem to find a feature that I use a lot in my work. I manufacture investment molds. So I get a drawing and have to add a shrink factor to it. I import customer supplied prints, then usually just "resize" them to make a mold print. For example a print dimension is 1.000" to which I add say 25% for a total of 1.25" on the mold I make. Is this feature available? If I missed it somewhere I apologize and appreciate a direction to head in. Thanks in advance! Richard
Hello Richard
If you are referring to resizing 2d drawings you can use the scale command. Its in the menu Modify - Transform - Scale
