Tony
#1 Posted : Sunday, March 27, 2016 1:56:41 PM(UTC)
Tony
Hi
Just started with ViaCad 2D/3D software. Created a 2D drawing relating to the side of a model railway carriage.
Process used
In 2D mode created a rectangle approx 1" x 8", then placed window apertures within the rectangle.
Moved to 3D, selected Trimetric View, 'select all' and then use Extrude Solid tool to add thickness to the rectangle. All looked as expected could see through the window apertures.
I then went back to 2D mode and attempted to add more windows and the system no longer allows the creation of an aperture.
Question
How can I add an additional aperture, preferable in 2D mode but any advise on a solution would be greatly appreciated.
Best wished to all
Tony
#2 Posted : Monday, March 28, 2016 7:02:13 AM(UTC)
Hi Tony
What happens when you try to add the new appetures?
Sounds like maybe you workplane is not xy when you switch from yrimetric back to 2d.
rokoko
#3 Posted : Monday, March 28, 2016 7:20:24 AM(UTC)
rokoko
hi,
go to 2d mode, create a polygon inside your profile (see picture 1, black polygon), next switch to 3d trimetric, select your block and open the feature tree in concept explorer. right click on the profile feature and choose add curve or polygon. then pick the new polygon
regards
Edited by user Monday, March 28, 2016 7:39:55 AM(UTC)  | Reason: Not specified
