macnavi
#1 Posted : Sunday, May 22, 2016 10:05:37 AM(UTC)
macnavi
Netherlands
I know you can turn off the tool tips, but it doesn't turn off all the tool tips. There is only one tool tip, which is not really a tool tip, that annoys me all the time, as it is constantly in the way:
When you want select a layer, immediately when you arrive there with your cursor, the layer name below is overlapped by a tool tip (in a white block). If you keep your mouse there, a tool tip with a yellow box appears. The last one is the one you can turn off in the preferences, but not the first one. The last, yellow one is not annoying, as it only comes up as expected, when the mouse arrow is on it for a few seconds. The first one should just completely disappear, or appear later. Now I have to move my mouse away from the layers panel, the move it back on a lower or higher level, then move it down or up to the desired layer. Or click on a layer.
It can even happen that you have two tool tips overlapping!
macnavi attached the following image(s):
Screen Shot 2016-05-22 at 17.04.29.jpg (22kb) downloaded 7 time(s).
24c
#2 Posted : Sunday, May 22, 2016 12:58:11 PM(UTC)
24c
Hi macnavi,
I don't have the same behaviour in OSX 10.11.5 and Shark FX build 1201
You can turn off Enable Tooltips, which should do away with the yellow hints.
I'm modding my Layers in the Concept Explorer Window
If the other really bugs you, you can disable this by using Terminal and altering a specific preference in defaults.write.etc
Mike
macOS Tahoe-v17 beta b1908
macnavi
#3 Posted : Sunday, May 22, 2016 1:30:50 PM(UTC)
macnavi
Netherlands
Thanks. I know the yellow ones can be turned off in the preferences. But as said, those are not bothering me, as they only come up after waiting a few seconds. I don't understand why there are two kind of tool tips and why that can't be turned off. I'll see what happens in 10.11.5, haven't done the upgrade yet. Still at 10.11.4.
